Quick LED bulb question (door panel / puddle lamp)
I just need a quick confirmation after doing a search:
Will LEDs for the front door panels (ie- from Sewell's LED interior kit) work in the mirror puddle lights as well.
From doing a quick search, it appears that they're the same size.
TIA,
Mike
TIA,
Mike
Yes, it takes the same 194 bulb. I hear the flank style bulb design works great. I have a 7 led round bulb in the mirrors and it shines quite a bit of light. Keep in mind however, the puddle lights don't put out much light no matter what shape of bulb you decide to install. But they look so much better than stock!
Are flanks better or the ones that fire in "all directions"? I tried both and I felt like the ones that fire in all directions were better given the reflective inside of the puddle lamp housing. I'll have both 4 LED flank and 8 LED bulb to test with in a while. I'll figure out out then I guess.
Don't spend that much on the Swell kit use this one I just purchased it looks awesome...
http://www.automotivelightstore.com/...ROD&ProdID=385
Then I bought these ones for the puddle lights
http://www.automotivelightstore.com/...ROD&ProdID=305
![](http://img4.imageshack.us/img4/5334/dscn0233n.jpg)
