TE37 for IS350 fitment question!!!!! help
03-25-09, 07:23 PM
I got a set of 19" TE37 on the way.
spec :
front : 8.5, +22
rear : 9.5, +34
quesion:
1) does stock TPMS adapter work with front and rear?
2) do I have to buy a set of Rays Valve Stem for the TE37? or I can used the stock 1?
03-25-09, 07:28 PM
I believe the valve stems comes with the wheel if the wheels requires spesho valves.
03-25-09, 07:47 PM
I would do +22 all around.
03-25-09, 07:59 PM
I want 2" lip in the rear, HEHE
03-25-09, 08:03 PM
It looks much better with the concaved look but that's just me.
03-25-09, 08:04 PM
2IS OG
Quote:
Originally Posted by
AK-47
spec :
front : 8.5, +22
rear : 9.5, +34
quesion:
Yes, you can use your OEM TPMS in the TE37's.
AK-47
Your valve stems will be your TPMS - it's all in one.
Javier
03-26-09, 06:29 AM
TE37's are so sexy
03-26-09, 07:43 AM
TE37 my car has tpms valves and they work fine i took the ones out of my stock wheels and put them in my TE37
03-26-09, 08:50 AM
Thank you all for the quick reply and help!!!!!!!!!!!!!!!
03-26-09, 11:46 AM
iSuxeL
I have a question for TE's. if you want the concave look do you have to actually ask for it when you order it or does it all depend on the offsets that you actually go by?
03-26-09, 12:01 PM
2IS OG
How concave the spokes are on the TE37 depend on wheel size (diameter), width, and offset.
Javier
Reason: typo
03-26-09, 12:54 PM
^^Like he said
03-26-09, 02:45 PM
javyLSU
Javier
so to get the effect like johnny's bronze TE's but with 10" wheel in the rear the offset would have to be in the mid to low 30's?
03-26-09, 03:12 PM
2IS OG
Probably lower. Think of it this way - the more distance the spoke has to travel from the center to the rim of the wheel, the more concave the wheel will be. I know the look you're going for - the 350Z/G35 guys enjoy this look, and the offsets on those wheels are usually in the teens.
Javier
03-26-09, 04:10 PM
I think if IIRC, a couple Suby guys that had TE's and CE's, the face didn't start getting concave until around a +22 offset.
