TPMS and Tire Pressure
I ran over a nail and after sometime the TPMS warning light came on. I got the tire fixed and put it back on. But the warning did not go away. I checked the pressure on the fixed tire and it was 35psi (rear). Which is almost same as specified in door. Would two PSI make a difference?
Thanks
Mir
Thanks
Mir
Did you check the other tires? Maybe another tire is low. I'm not 100% sure but 2psi shouldn't make a difference... I think the light comes on when the psi drops to like 27 (assuming you're using the factory settings).
RiojaRed
09-25-17 11:54 AM
Jeffrimerm
01-01-15 12:05 PM
