Question on Lexus LED flasher & Amber turn signal bulbs from V-LEDs
Old 04-06-09, 11:25 AM
Dj_AmtraX
Dj_AmtraX's Avatar
Default Question on Lexus LED flasher & Amber turn signal bulbs from V-LEDs
I have the Toyota LED flasher from V-Leds. It fixed the hyper flash problem but killed the stock alarm arm/disarm flashes. I bought the flasher a little over a year ago so I don't know if the new Lexus LED flasher they now offer fixes both problems. If you have it installed, please provide some feedback on this product. Thank you!
Also, the 7440 LED (amber) I have aren’t bright enough and it is hard to see in the day. V-Leds now offers several versions. I was hoping to get some user feedbacks on this too so I know which to order. Thank you!
Old 04-06-09, 11:55 AM
jns350
jns350's Avatar
I have the same flasher I bought not too long ago. I was warned that the alarm flash will not work period. That was the trade off. You can go a different route and use load resistors instead. You will need 4 of them for both front and rear (3ohm 50amp load). This will allow you to remove hyper flash and still regain the function of the alarm flash feature. BTW..your a DJ..I thought you would like the hyper flash detail..hehehe J/K good luck.
Old 04-06-09, 11:59 AM
acefalcon2
acefalcon2's Avatar
i did the load resistor on a honda it's a 15 min thing it's okay without those clips... some tape and the thing to expose those wires..
Old 04-06-09, 01:26 PM
T4styPh0
T4styPh0's Avatar
That's something I was wondering for awhile now. Since there are 4 turn bulbs up front, wouldn't you need a resistor for each?
Old 04-06-09, 01:45 PM
jns350
jns350's Avatar
From what I understand...50 amps is plenty for the pair of turn signals on front. But I can't confirm from experience
Old 04-06-09, 02:15 PM
Dj_AmtraX
Dj_AmtraX's Avatar
I ratter not have alarm flashes than to cut/tap the stock wires. I was hoping they have it resolved with the "Lexus" version.
Old 04-06-09, 02:19 PM
Dj_AmtraX
Dj_AmtraX's Avatar
My reverse lights are strobes. Gives a god light show to drivers behind me.
Old 04-07-09, 09:58 AM
iLexi
iLexi's Avatar
Where did you get the strobe lights
Old 04-07-12, 12:00 PM
RBnSD
RBnSD's Avatar
did anyone by chance ever find out if you need the 4 resistors up front?
Old 04-07-12, 12:54 PM
GiantsFan
GiantsFan's Avatar
Just modify your OEM flasher!! I'm using VLEDs "platinum amber" LEDs and they are nice and bright!
Check out the DIY on my build thread:
https://www.clublexus.com/forums/is-...-thread-3.html
http://v-ledsblog.com/2010/12/02/how...k-with-v-leds/
Old 05-04-15, 02:32 AM
LexoticJ
LexoticJ's Avatar
There's got to be an easier way.
Old 05-04-15, 04:59 PM
5nX37
5nX37's Avatar
There is. I installed this http://www.diodedynamics.com/store/2...signal-flasher the other day. Everything works.
Old 05-04-15, 11:27 PM
LexoticJ
LexoticJ's Avatar
Can you post a video of this flasher making the arm disarm work.
Old 05-08-15, 10:50 AM
LexoticJ
LexoticJ's Avatar
Ordered the flasher. Hope all goes well
Cconnors09
12-29-15 02:23 PM
TRACKMKIII
GS - 1st Gen (1993-1997)
01-09-15 06:17 PM
Dj_AmtraX
04-28-07 12:18 PM
Quick Reply: Question on Lexus LED flasher & Amber turn signal bulbs from V-LEDs
