hub centric ring needed with new Works?
awesome, probably one of the most productive threads I've started haha.
now what about lug nuts, will any 12x1.5 work with the works? i was thinking of RAYS or mcgard.
from what I've read, doesn't really matter if you go open/closed or short/extended?
yea, any 12x1.5 should fit your Works. Personally I'm using a set of Rays shorty lugnuts with my Works.
Its all preference. From a functional standpoint closed is the better choice since open leaves the threads susceptible to rust. IMO extended and neo-chrome are a bit ricey.
Do these look good? They're really cheap too!
http://cgi.ebay.com/ebaymotors/73-60...051510007r3653
not true
My T1S and the Works on there way do not require rings. They are 60.1. Only down fall is I am limited to our bolt patter and 60.1....off the shelf they may require depending on where and who you get them from. Really doesnt matter.
I agree go to Discount and get them. I have never once had a problem in the past and they are cheap.
not true
If you're going to need the rings for aftermarket wheels why would you care if the ring seized on the hub? You're going to reuse them anyways right? Anyways I'm getting the HIGH QUALITY POLY CARBON LOL ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Speaking of the Aluminum vs. Polycarbonate Plastic Hub-Centric Ring Adapter debate, I found these BILLET ALUMINUM Hub-Centric Ring Adapters for $100/set here:
http://www.motorsport-tech.com/hub_rings.html
Can anyone post clear photos of the mass-produced $24.99 "plastic" and $34.99 "aluminum" Hub-Centric Ring Adapters sold by "1010tires" (or similar) for long term group benefit of having a visual comparison with the custom-order American-made CNC "Billet Aluminum" design above...?:
http://www.1010tires.com/hubrings.asp
Speaking of some stating the propensity of "Aluminum Hub-Centric ring adapters to 'seize' to the Hub" (via oxidation and/or thermal fatigue), I found this link addressing the seizing issue via the use of 'anti-seize' compound:
http://www.billetprototypes.com/Hub_...g_Install.html
http://shop.billetprototypes.com/pro...c?productId=93
Engineering Overkill?? Perhaps.
They are $65 more than the aluminum ones at 1010tires.
I have to do a bit of research on the oxidative and thermal fatigue properties of the (nonspecified) type of aluminum used by "1010tires" vs. the type of billet aluminum used by "Billet Prototypes" above.
It is nice that 'Billet Prototypes will CNC mill to whatever precise specification you request However, the ones from "1010tires" may already be more than adequate with regards to original manufacturing tolerances
Again, it would be nice if someone can post some photos of the aluminum and/or plastic Hub-Centric Adapter Rings from "1010tires" for visual comparison with those produced by "Billet Prototypes".
However, it seems to me that Hub-Centric Ring Adapters have a CRITICAL role to play and are not something one would want to risk with gradually falling out of original tolerances to thereby slowly place hidden undue mechanical stress upon very costly and safety-critical suspension components.
tresvatos
05-07-12 02:08 AM
