hub centric ring needed with new Works?
Old 04-06-09, 03:54 PM
vtrusty
vtrusty's Avatar
Default hub centric ring needed with new Works?
will i need a hub centric ring for my new Work SC1s?
Old 04-06-09, 04:18 PM
johnnyboy
johnnyboy's Avatar
i didnt have rings in any of my works.. never vibrated
didnt have em in volks neither.
you shoudl be fine with no rings
Old 04-06-09, 04:29 PM
BoOst3d
BoOst3d's Avatar
as long as u have the right lug nuts u should be fine....cone-shaped
Old 04-06-09, 04:46 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,060 Likes on 2,457 Posts
No doubt you could use them. It's not like they're expensive anyway. You really do want the wheel centered, not floating. Keep in mind the studs weren't intended to support the entire weight of the car, that's why the OEM wheel centerbore is the same as the hub centerbore. The other thing about conical lug nuts is the need for a decent torque wrench to install the wheels is much greater to ensure the load is evenly spread across all five studs. Tightening by hand and guessing at torque isn't recommended.
From here.
Q: Exactly, what does hub centric mean?
A: Hub centric wheels are manufactured so that when they are installed on a vehicle, the wheels are located directly off of the center flange of the brake drum or rotor. This is done to insure that the outer beads of the wheel are concentric with the wheel bearings. The result is a much truer, better balanced tire/wheel assembly. This is very important with modern high tech suspension systems.
Q: What about the phrase “Lug Centric”? Isn’t it just as good?
A: NO! Lug centric is a marketing phrase made up by the few manufacturers who don't offer hub centric wheels. Their theory is that if the wheels are drilled for conical seat lug nuts, then the wheels will self locate. Surveys have shown that most installers just hang the wheel/tire combination on the studs and put on the lug nuts expecting the angle of the conical seat to pull the wheel/tire combination into concentricity.
Recent tests by several major wheel manufacturers have shown that when the above mentioned mis-locating occurs the studs actually bend down slightly thus creating an artificial out-of-round condition by as much as .0025. Consequently the custom wheel often gets a bad rap
because of a poor installation job. Hub centric wheels or hub centric rings will correct this situation.
Old 04-06-09, 05:15 PM
Wierdazndu
Wierdazndu's Avatar
i dont think you would neeb hub centric rings at all
Old 04-06-09, 05:18 PM
iSuxeL
iSuxeL's Avatar
I wouldn't disagree with lobuxracer if I were you
Old 04-06-09, 05:29 PM
javyLSU
2IS OG
javyLSU's Avatar
From here.
Go to America's/Discount tire and spend $15 for some hub rings. Most aftermarket wheels are made with a 73mm hub size so they can fit most any vehicle's hub, and your Lexus has a 60.1mm hub size. Verify the hub size with Work USA, or you can wait until you get your wheels and either measure the hub size yourself or have Discount tire/whatever shop you buy from measure it for you. Assuming Work makes their wheels with a 73mm hub size, you'll then need a 73-60.1mm hub ring. Get the plastic ones - they're cheaper and like Lance's link mentioned above, and they're actually better than the aluminum ones.
Javier
Old 04-06-09, 05:37 PM
mikez
mikez's Avatar
Or prepare for the consequences lol.
I use the 73-60.1 ones from Work
Old 04-06-09, 06:50 PM
Coconut
Coconut's Avatar
$15 for added safety and piece of mind. You do the math.
FYI you need the 73mm - 60.1mm hub rings.
Old 04-06-09, 06:54 PM
SoCal35
SoCal35's Avatar
You COULD go without hub centric rings. I know lots of folks who don't use them. At the same time, I don't think it hurts to get them. They're inexpensive and they give you peace of mind. I personally decided to buy them because I don't think it hurts to ensure that your wheels are more precisely centered. Just my opinion though.
Old 04-06-09, 07:13 PM
iSuxeL
iSuxeL's Avatar
Why are the plastic ones better than the aluminum ones?
Old 04-06-09, 07:23 PM
VikH
VikH's Avatar
The aluminum ones can sieze to the hub.
I got the 73-60.1 for my Volks from Discount. Might as well for $15.
Old 04-06-09, 07:37 PM
iSuxeL
iSuxeL's Avatar
Do Work wheels use the same sizes?
Old 04-06-09, 07:39 PM
mikez
mikez's Avatar
Yeah all Work wheels are 73mm diameter in hub
Old 04-06-09, 07:41 PM
iSuxeL
iSuxeL's Avatar
Sweet! Guess I'm getting some plastic ones LOL
Quick Reply: hub centric ring needed with new Works?
