LED door handles, been done?
#46
Yep, this should have been standard with the IS. At least we have the rear plate LED's.
#48
this is going to be one of my projects for summer. now i just gotta get the right leds
any suggestions guys? i want pure white with a hint of purple just like hids. i'll also do a writeup after i get this completed.
#49
Looks easy to do...
I think it is...
White LED's 5MM
http://www.radioshack.com/product/in...ductId=2102852
![](http://rsk.imageg.net/graphics/product_images/pRS1C-2265172w345.jpg)
Then flush mount w/ 5MM LED holder..
http://www.radioshack.com/product/in...ductId=2062558
![](http://rsk.imageg.net/graphics/product_images/pRS1C-2160468w345.jpg)
I use to use this for interior lighting.. not too sure how well it will work since it will be weathered... exposed to the elements..
I think it is...
White LED's 5MM
#50
i was soo going to do it.. you can run a relay using the puddle lamp ground side to close the contact for the LED.. this would allow the led to come on and off with the puddle lamp.. i'm sure you can splice into the puddle lamp power supply, but you run the risk of surging the line, its just safer with the relay.. (not that the LED draws alot of power, but safer is always better) if i ever have time to do this, i will share with everyone.
#60
there's a picture of it floating around somewhere here...
i think it'd pretty much be the same parts as this mod...
from what i recall you just have to connect it and wire it up to your puddle lamps... but a DIY... i've been waiting for one
