Non-ML Sub Install - Ignition Power Source
I have got my sub completely installed, except I cannot find an ignition power source to start my amp. I have searched extensively and cannot find a definitive answer as to which wire to tap. I tried the orange and both the pinks on the connector closest to the back of the car (according to this thread https://www.clublexus.com/forums/is-...-pictures.html), and the amp will not turn on. If I tap a hot source, the amp works, so I know that this is the issue.
Help!!
Help!!
Here you go.
I ran the power from the battery according to this post:
Then, there are 4 plugs on the amp--we will number them 1 to 4 with 1 being the plug closest to the tail lights and 4 being closest to the headlights.
The ignition power lead is on plug 2 and is orange:
The speaker leads are on plug 3 and are brown (Left +), lime green (Left -), pink(Right +), and light blue (Right -):
My amp has line level inputs, so I did not install a LOC.
Hope that helps someone in the future.
sc4009688
12-12-05 05:33 PM
