Is it possible to personalize settings without dealer? (Daylight, autorecirculation)
I heard about CBEST and LPS that can be done by the dealer, but, may be it is possible to change these setting without going to dealership?
1) I want may headbeam to work always (no matter if there is day or night on the street). In headbeam ON switch position, after turning off the engine and opening the drivers door, I've got the headbeam turned off, but the sidemarkers (parking lights) are still glowing, even after 5 minutes. So I need to manually turn off the switch.
On AUTO mode, all the lights goes off after engine is turned off, but there no light at daylight.
So, there 2 ways to solve the problem:
a) Change the sensitivity of the daylight sensor, so it will turn on the headbeam even at daylight.
b) Turn on some kind of "sidemarkers auto off" feature.
2) Is it possible to make the permanently activate "auto air recirculation" feature if there no hardware button on the console? Originally, my car had that button, but after retrofitting the OEM monitor, I've lost that button.
lps settings must be done by the dealer. the only thing you can do yourself is toggle between the driver door or all doors unlocking when you grab the driver handle.
1--this shouldn't be. something's wrong. it should all turn off.
a-this won't do anything for your problem. all lights should turn off after the lps time setting regardless of the lps light sensitivity.
b-doesn't exist yet?
2--i thought there was an lps setting for this?
rayaans
RX - 3rd Gen (2010-2015)
26
03-15-18 06:11 AM
mikevanle
03-08-07 10:15 AM
