Front Wheel Bearing DIY
Old 04-17-09, 01:39 AM
THoon
THoon's Avatar
Default Front Wheel Bearing DIY
Anyone have any instructions on replacing the front wheel bearings? Is it pretty easy or should I take it to a shop? I saw a couple videos on YouTube for replacing wheel bearings on other cars and it looked pretty easy. The IS has a sealed bearing and the bearing and hub is one unit so you basically have to replace the entire hub.
Old 04-17-09, 06:28 AM
vdubturbo
vdubturbo's Avatar
Are you sure its not just a press fit? Wheel bearings aren't hard for an intermediate mechanic, but it requires some tools the average person might not have. And its a very dirty job.
Old 04-17-09, 06:45 AM
Gator Alum
Gator Alum's Avatar
Front wheel bearings are just press in. I switched mine out for the IS-F wheel hubs bc of my new brakes. It's four bolts. Make sure you get the correct torque values for them. Best way to get them out is to mount a wheel back on the hub and don't tighten the lugs all the way down. Then give the wheel/tire a quick jerk to pull it off and the hub will come with it. I included a picture of what a hub looks like. This compares the IS-F hub to the IS350 hub.
Old 04-17-09, 09:53 AM
THoon
THoon's Avatar
My dealer said the bearing and hub are one unit so I need to replace the whole hub. It's $650 to have them do it. If I just changed out the whole up do I don't need any special tools right? Just remove the brake calipers, rotor, and remove the hub right? What's the torque specs for a 2007 IS250?
Old 04-17-09, 10:20 AM
Gator Alum
Gator Alum's Avatar
The hubs are about $300ish from Sewell. You don't need any special tools, just some sockets and wrenches. As far as torque specs, I looked them up on TIS.
Install the front axle hub sub-assembly and front disc brake dust cover with the 4 bolts.
Torque: 69 N·m (702 kgf·cm, 51 ft·lbf) (Same for 2WD and 4WD)
If it's AWD, Using the socket wrench (30 mm), install a new front axle hub nut.
Torque: 294 N·m (2,998 kgf·cm, 217 ft·lbf)
AARONHL (02-03-18)
Old 04-17-09, 11:11 AM
blk250
blk250's Avatar
nice..Gator..
Old 04-17-09, 11:23 AM
Gator Alum
Gator Alum's Avatar
no prob. glad I can help
Old 04-17-09, 02:43 PM
zak21
zak21's Avatar
The IS350 and IS-F hubs look very similar, what is the difference between the two?
Thanks
Old 04-17-09, 02:50 PM
javyLSU
2IS OG
javyLSU's Avatar
The IS-F hubs are longer, increasing the front track width of the IS-F over the ISx50.
Javier
Old 04-17-09, 04:12 PM
sinister2c
sinister2c's Avatar
if you know how to change rotors and brakes...you can replace the hub assembly.
Old 04-18-09, 03:06 PM
THoon
THoon's Avatar
What would be a droning/oscillating sound like a waaah....waahh........wahhh... sound besides a wheel bearing or tires? I can hear the sound at around 40mph and then at over 80mph I feel it. It's a really slow vibration. The "waaah" is about 1 to 2 seconds long. It goes away when I turn right at over 80mph but I hear it pretty loud on a nice smooth round. Since I feel it when I turn left, does that mean i should replace the right wheel bearing? I'm also getting more wear on the inside of my left tire. I also had my car aligned but it still pulls to the right and the steering goes to the right as well by itself.
Old 03-18-12, 12:22 PM
08lexus350
08lexus350's Avatar
hey guys i just replaced my front wheel hub on my lexus is350, i had my abs vsc and traction light on, i thought after my change of the hub it would go off and it didn't. any idea why it didn't or do i have ti take it to the dealership., thanks a lot
Old 03-25-13, 08:29 AM
javiereok
javiereok's Avatar
Default Weel bearing hub
I have a question, looks like I need to replaze the wheel bearing on my lexus is 250 - 2006, I bring the car to a local mechanic and he said it is a dealer fix because if he remove the weel bearin he can look the car, he said any regualr mechanic shoop can not do because is a special fix. It is tru or false? Any advice?
Thanks.
JR
Old 03-25-13, 05:59 PM
Gville350
Gville350's Avatar
If they are not comfortable with removing the wheel, removing the ABS sensor wire, and removing the 4 bolts holding the hub onto the knuckle...then DEFINITELY go somewhere else!
Old 04-01-13, 05:42 AM
javiereok
javiereok's Avatar
Thanks, any pictures? or do you know any link with a good graphic info?
Quick Reply: Front Wheel Bearing DIY
