IS350 'ticking' noise from the engine
Old 04-23-09, 09:53 AM
aboss3
aboss3's Avatar
Default IS350 'ticking' noise from the engine
I got a 2006 IS350 60kmi, and recently after an oil change (did a 10w-30 instead of 5w-30) I started hearing a 'ticking' noise comming from the engine. It get lowder when put in reverse. Some forums state that it's a common problem with all IS2x since it has a direct injection, and that's where the noise is comming from.
Can anyone confirm that? Or has anyone experienced the same thing?
Old 04-23-09, 10:07 AM
highstakes
highstakes's Avatar
Yeah, its the DI.
Old 04-23-09, 10:11 AM
GiantsFan
GiantsFan's Avatar
I have that noise too... It's the DI
Old 04-23-09, 10:12 AM
IS-SV
IS-SV's Avatar
Yes normal for D.I., noticed it the first time I drove it.
Old 04-23-09, 10:16 AM
aboss3
aboss3's Avatar
So there's no way to get rid of that?
Old 04-23-09, 10:18 AM
slee18
slee18's Avatar
you mean you didnt hear the ticking before your oil change or has it gotten louder?
Old 04-23-09, 10:21 AM
aboss3
aboss3's Avatar
I didn't hear that before the oil change. So my initial guess was that's due to the oil being heavier (10w vs 5w), but everyone suggested that it's normal.
Old 04-23-09, 10:30 AM
slee18
slee18's Avatar
you might want to check if it is ticking or knocking. I know some had problems with a knocking on startup. The ticking should have been there in the beginning not after an oil change.
The ticking from the DI should sound like a pen when you click it to write with.
Old 04-23-09, 01:24 PM
four o two
four o two's Avatar
It's normal. No way to "get rid of it."
Old 04-23-09, 02:33 PM
Lexminster
Lexminster's Avatar
I put some chevron techron fuel injector cleaner in mine and it helped subside the noise a bit, but the noise is normal.
Old 04-24-09, 04:58 AM
Bichon
Super Moderator
Bichon's Avatar
Direct Injection noise has absolutely nothing to do with the weight of your oil. The noise is completely normal; someone asks about it here every few weeks.
Why did you put 10W30 in? A TSIB that came out after your car was manufactured changed the recommended oil to 5W20. 5W30 is also acceptable. If I'm not mistaken, the owners manual specifically advises NOT to use 10W30 on a long-term basis.
Old 04-24-09, 08:54 AM
slee18
slee18's Avatar
It says to change it out the next oil change.
Maybe that is why he is only getting the ticking sound more after the oil change. The oil isnt reaching the cams fast enough at startup.
LordBowral
06-10-15 07:46 AM
genin9
RX - 1st Gen (1999-2003)
12
04-21-15 09:16 AM
niteflite
07-17-10 08:00 AM
EthanV
11-26-08 07:41 AM
lexudv
11-30-06 12:09 PM
Quick Reply: IS350 'ticking' noise from the engine
