★★★★★ Official Five Axis Design Wheel Thread ★★★★★
#136
you should be able to go with a +35 offset and still be good. but it also depends how low your drop is. i have offsets in the mid +35 with the same diameter and width your looking into and the rubbing is not that bad. it only rubs when i make fast sharp turns, nothing to serious. i also have a 1.25" drop. +45 offsets is really conservative, it'll basically look like the stock wheels in terms of the flushness.
also you might want to reconsider running a staggered set up on an AWD drive. i've heard running a staggered set up on an AWD can mess up your tranny or differentials or something like that. dont ask me the specifics cuz i dont know to much about it, but maybe someone here can explain it better.
#137
Thanks for the advice, but I just thought that since stock is +45, if i do +45 with 8.5 in the front and 9.5 in the rear, don't i stick out .5 inch more than stock in the front and 1.5 inch more in the rear? I want it to not rub at all, so what would be the most aggressive offset I can go without rubbing? Thanks!!
BTW, i'm lowered on H&R so i think its something like 1.4" drop in the front and 1.3" in the rear or something close to that
#138
Received 1,064 Likes
On this wheel it will be the +45 for NO RUBBING... on a regular ISx50
+35 in the front will require fender tab modifications for sure.
Especially if dropped and if with 235/35/19 tires
Joe Z
Joe Z
#139
a wheel with a wider width does not necessarily mean it will stick out more. the actual wheel will be wider but it is the offset (which is distance between the centerline of the wheel and hub-mounting surface of the wheel) that determines how much it will stick out. the higher the offset the more your wheels will tuck into the fender, the lower the offset the more it will stick out.
+45 would be the safest setting you can go with to NOT RUB AT ALL, but it will look just like stock in terms of how much your wheels stick out. you also might be able to get away with it +40 without any fender modification.
and yes with +35 you will have to modify your fender for sure, in order for it to not rub AT ALL, but in my previous post with my +35 i do rub but its not that bad. hope this helps.
also you might want to talk to your wheel dealer about running a staggered set up with an AWD to make sure it wont mess up your car in the long run.
#140
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Since the NEW R5:F wheel design just arrived it was time to bump this thread....
Show off your Five:AD Wheels!!!
Specs:
Five:AD | R5:F in GunMetal
19x8.5" +30 Front
19x9.5" +35 Rear
Tires:
Continental ExtremeContact DW
235-35-19
265-30-19
![](https://www.clublexus.com/gallery/data/4767/Picture_094a.jpg)
![](https://www.clublexus.com/gallery/data/4767/Picture_152a.jpg)
![](https://www.clublexus.com/gallery/data/4767/Picture_160a.jpg)
![](https://www.clublexus.com/gallery/data/4767/Picture_127a.jpg)
Special Thanks to Troy Sumitomo & the Five Axis Design team once again!!!!.
Just a heads up that the exact wheels in my 1st post are going up for sale by this weekend..
More pics to come, but I just have these few to share for now!!!
Enjoy,
Joe Z
Specs:
19x8.5" +30 Front
19x9.5" +35 Rear
Tires:
235-35-19
265-30-19
Enjoy,
Joe Z
#141
looks badass joe!!!!
#142
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
I feel +45, although is safe for scrubb free ride, move to far in for the agressive look.
Could you please elaborate, or even better with the pictures of where and how to modify the fender tab that you referred to?
If it's just a minor, easy modification, I might consider doing it in exchange of being able to run more agressive offest...
#144
Thanks Dean!!! FINALLY...
I added a couple of more pics above, we sure did miss you this past weekend at the Pursuit 2..
We should get together soon for a photo shoot.
Joe Z
#145
Thanks for your comments (as I am looking for a set of wheel as well)
If it's just a minor, easy modification, I might consider doing it in exchange of being able to run more agressive offest...![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
On the ISx50:
The front fender bolt tab is located at the edge of the front fender and bumper connection, under the plastic liner..
All you need is a dremel & some patience.
Joe Z
#149
#150
Looks good anyway
Tell me if it rubs crazy after put on the spacer?
