225/35/19 on 19x8.5 & 245/35/19 on 19x9.5 - Too much of a stretch?
Old 04-25-09, 04:38 PM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
Well, I'm not into stretching tires. I'll admit it looks good but now you are risking your rims, ride quality and the performance.
Getting correct sizes for different rims is not that hard. If you look on tirerack, you'll be able to find the minimum and maximum rim width you can use to for a particular tire size. Theoretically, you want to keep your overall diameter to be as close as to the stock diameter so that your speedometer will read the speed correctly.
For, 8.5" width rim, you will have no issue using 225/35 tires. For 9.5" width, if you want to do it properly, you can go with 255/35 or 265/35 tires. We can debate if stretch look is the way to go or not all day long. It will be your personal preference.
Terrance
Old 04-25-09, 05:15 PM
javyLSU
2IS OG
javyLSU's Avatar
Depends on the brand of tire you use, too. Michelin, who is known to run on the conservative side with their approved sizes, says you can go as small as a 245/35/19 PS2 on a 9.5 inch rim, while Toyo says you can run a 235/35/19 T1R on the same size wheel - so 245/35/19 on a 9.5 inch wide wheel wouldn't be "stretching" the tire by any manufacturer's standards.
Javier
Old 04-25-09, 06:24 PM
ISheaven
ISheaven's Avatar
those sizes should be fine. if anything its a very conservative stretch.
Old 04-25-09, 07:35 PM
carchitect
carchitect's Avatar
Originally Posted by Little E
Define the "correct size tires" when running 19s. It all depends on your set up (suspension modifications) and your wheel specifications.
Originally Posted by IS-SV
I'd like to know the answer too. Still hasn't been answered.
Correct size tires means to get a matching set of the wheel to the tire according to the recommended width of that tire manufacturer. Tire rack has the specs to them on their site. When matching the wheel to the tire one should stay at the recomended width. My IS350 uses Volk LE37T 18X8.5 +40 and 18X9.5 +40 with 235/40/18 and 275/35/18 respectively. They are at the recommended wheel width.
Old 04-26-09, 12:43 AM
LILDANTE79
LILDANTE79's Avatar
Originally Posted by mdgrwl
So I'm thinking of going w/ these tire specs and wondering what you feel about this... I'm thinking its a good fit, but wondering whatchall think?
225/35/19 19x8.5 - 245/35/19 19x9.5 it wont even stretch i have these sizes and they dont stretch at all. i have falkens no much of a difference. now i have 215/35/19 19x8.5 - 245/35/19 - 19x10 on my new wheels and they stretch nicely with toyos..
Old 04-26-09, 07:43 AM
acefalcon2
acefalcon2's Avatar
i've got 235/35 on a19x9.5... not much of a stretch... looks good tho!!
Old 04-28-09, 10:41 AM
IS-SV
IS-SV's Avatar
That's how I was viewing it for sizing. I use f/r on 19x8.5 and 19x9.5 wheels 235/35/19 and 275/30/19 on my IS.
I really don't understand how stretching looks better or improves performance. But I do understand how it helps with fender clearance with aggressive offsets.
Old 04-28-09, 01:14 PM
vtrusty
vtrusty's Avatar
not to thread steal, but i have 19x8.5 all around, would you all recommened 235/35 or 245/35?
sorry, im new with wheel/tire setups.
Old 04-28-09, 01:24 PM
mdgrwl
mdgrwl's Avatar
DEFF 235/35!!!! 245's are huge on a 8.5. lots of rubbing if your lowered
Old 04-28-09, 01:29 PM
ChrISF
ChrISF's Avatar
^ what he said.
Old 04-28-09, 03:44 PM
vtrusty
vtrusty's Avatar
since 245 is out of the question, should 225s be considered?
Old 04-28-09, 05:32 PM
datplayaz
datplayaz's Avatar
what's your offset on the rim? and are you drop on anything (plan on dropping it)?
F_Throttle
IS F (2008-2014)
10-23-17 03:10 PM
3sgte_slow
05-19-12 10:14 AM
Damaster32
05-09-10 05:36 AM
ummagawd
Wheels, Tires & Brakes Forum
06-26-06 03:35 PM
Gs L-tune
14
09-06-05 02:26 AM
Quick Reply: 225/35/19 on 19x8.5 & 245/35/19 on 19x9.5 - Too much of a stretch?
