How to manually change the timezone on NAVI?
IS250 2007
I've got navi unit from USA, using it with European maps, there some troubles with it (it dont give english voice guidance and dont show POI as icons on the maps) but the main problem, is that I could not change the timezone to european. In menu it allows to select on US continental zones, no way to enter f.e. GMT +3 and so on...
Does anyone know how to fix it? Or may be there is more complete way to convert the entire system from US to EU?a
When you are in guidance, if you touch the block with the arrival time, a menu will fly out, and, instead of arrival time, you could select remaining time to destination. It won't fix your problem, but you won't see the incorrect time.
jiodaqmke
07-02-11 09:42 AM
