^ Maaan, i contacted Hondata and asked whether they had a kit for the VTEC on my IS250 and they were like, "Lexus doesn't have VTEC". Obviously they don't know much about cars.
For a 350, disable the traction and VSC. No need to pre-heat the tire (burn out) and you may not even need to preload the trans (Rev-up). Use two feet to release the brake while gassing it. The object is to leave without spinning the tire. You can lower the air pressure till the tire doesn't spin. Full auto, no paddles and no sport mode.
when I race I drop the tire pressure to 21psi pedal dance to take traction control off do a burn out line up where I did it brake+Rev to 2000-2200 arm the nitrous Hit the gas and the Button and run mid 12's
How many shot nos you running and do you have a wideband watching your a/f ratio?
its a 50 shot that i put on a 30 shot and it was barely noticeable and no I dont have a wideband but im thinking i should probably get one soon Im taking my cats out of my headers this week to see how that helps
Man that sucks I was hoping they wouldve had one, that wouldve given us like 100+HP...lol
well we dont really have vtec (Variable Valve Timing and Lift Electronic Control). We have vvt (variable valve timing). They do work a bit differently and hondata only works with honda anyways.
You guys are all doing it wrong! I arm my 500 shot of nitrous. Turn on my underglow. Then turn on my emergency lights. Then rev to 9000k and drop my clutch. This is the best method to launch, you'll smoke any car on the road.
