If the key FOB dies can you start...
Old 05-02-09, 06:07 AM
EJC
EJC's Avatar
Default If the key FOB dies can you start...
If the key FOB dies can you start the IS?
I know you can use the key to open the door, but is it possible to start the car w/ dead batteries in the Key FOB?
Old 05-02-09, 06:49 AM
datplayaz
datplayaz's Avatar
From what i know, you can still start the car if you hold the key fob near the start button
Old 05-02-09, 06:56 AM
nmpeter
nmpeter's Avatar
I'm pretty sure you can, I doubt they would design a key that doesn't work after the battery dies.
Old 05-02-09, 06:58 AM
Tree Fiddy
Tree Fiddy's Avatar
Just like the doors, you pop off the cover of the start button and there is a slot for the key to go into.
Old 05-02-09, 07:50 AM
Kurtz
Kurtz's Avatar
No there isn't.... you hold the "dead" fob right up to the start button and it'll start. Pretty sure it's in the owners manual too.
Old 05-02-09, 07:55 AM
Individual
Individual's Avatar
Actually, there is nothing behind the push start button to insert the key into. There is a TSIB(L-SB-0161-08 Smart Key Intermittent No Crank/No Start), where they replace the push start button, and there is no slot behind the button to insert the key into. You simply hold your key fob, with the dead battery, right up to the start button, and it will light up and you can start the car. I've done this several times to some cars that come in for service and so far it's working as intended.
Old 05-02-09, 07:56 AM
mvlbr
mvlbr's Avatar
I was told the same thing when I bought my car.
Old 05-02-09, 09:15 AM
tex2670
tex2670's Avatar
You hold the fob touching the start button and push it.--it works, I've done it. Even with the battery dead, it throws off a little signal
Old 05-02-09, 12:30 PM
2slow
2slow's Avatar
You cannot insert anything into the start button. On the driver side door handle you can pop off the cover and put the key in there, but no where else.
Old 05-02-09, 12:37 PM
ankurman20
ankurman20's Avatar
Yeah there is nothing to insert behind the buttom, and plus it too of a hassle... Just hold the dead key fob close to the start button and turn on the car like you regularly would...
Here is some proof
http://www.youtube.com/watch?v=m1KdvOQxP-o
Old 05-02-09, 12:48 PM
350PsDMeuP
350PsDMeuP's Avatar
yeah hold it up to the start button and it should start!
Old 05-02-09, 01:51 PM
four o two
four o two's Avatar
WTF? No. Did you just come up with this all on your own? What is the deal with people like you just blatantly spouting misinformation? Wow.
Old 05-02-09, 01:55 PM
TinCan
TinCan's Avatar
so anyway...there is this thing in the glove box....
it's called a manual...
and it shows you how to start and remove the door lock cover on your car!!
Old 05-02-09, 01:57 PM
eric_r_ho
eric_r_ho's Avatar
Yeah, roite. This isn't a Mercedes-Benz where the push start button is a dinky plastic attachment..
Old 05-02-09, 02:34 PM
Bichon
Super Moderator
Bichon's Avatar
Nope, that's not how it works. It uses passive RFID. When you hold it next to the start button, the reader generates a strong electromagnetic field that induces a current in a coil in the fob, which powers the dead key long enough to start the engine.
Most electric toothbrushes are charged this way. No direct electrical connection -- the charging base induces a current in a coil in the toothbrush handle.
Quick Reply: If the key FOB dies can you start...
