Turn Signals not working
05-04-09, 01:02 PM
Hello all,
i have an 08 is 250 and my turn signals are not working but my Hazard does work fine...
any ideas what this can be?
05-04-09, 01:19 PM
fuse? bulb? it's hard to trouble shoot without any other info. did you mod the bulbs?
05-04-09, 01:20 PM
its not the bulb becuase the hazard works when you turn it on
05-04-09, 01:21 PM
Quote:
Originally Posted by
tex2670
fuse? bulb?
I would go with fuse. If it was a bulb, I would think the remaining bulb would flash faster indicating the problem.
05-04-09, 01:23 PM
the fuse for the turn signal is located under the dash?
05-04-09, 01:38 PM
it is under your steering wheel i think... try looking in the manual... it is either on that side or on the engine bay
05-04-09, 02:10 PM
the flasher is probably bad. wouldnt be the fuse because then the lights wouldnt work.
05-04-09, 03:57 PM
if the flasher is bad then the hazard shouldn't flash too no?
05-04-09, 05:37 PM
thats the thing the hazard is working perfect
02-04-11, 12:19 PM
Any updates on this. I'm having the same problem. My turn signals dont work at all
02-04-11, 04:00 PM
Question? Where is the flasher relay?
02-05-11, 10:48 AM
Bump! Any help or followup on this would be great!
01-31-12, 02:10 PM
VPIS350
I would also like to know
01-31-12, 02:46 PM
It's somewhere near the floor pedals from what I know hiding behind a kick panel of some sort.
04-18-20, 08:56 AM
Misspelled words
CCJ22
the fuses are located under( and little over towards door) the steering wheel down towards the floor. The cover is clear and about 2"×3" also one located below glove box and one in trunk on far left side. Have to practically stand on your head to see inside the fuse boxes!
shlomy2000
09-10-23 12:41 PM
bio3m
SC- 1st Gen (1992-2000)
07-29-11 03:59 PM
AndyG
03-04-11 10:30 AM
Cochisecc
11-20-09 08:54 PM
mcamson
Lighting
10-03-09 12:09 PM
2006 ,
250 ,
300 ,
blinker ,
blinkers ,
es ,
fuse ,
is250 ,
is350 ,
lexus ,
signal ,
signals ,
turn ,
turning ,
working
