Window Switch Problem
Long story short.... I disconnected my battery from my car because I was installing my amp wires. In the process I switched to gold plated terminals and also an optima yellow top battery. I reconneced everything and everything works fine.
HERES THE PROBLEM: Driver side window switch works ONLY for driver side window. Doesn't work to roll down or up for any other windows. However, the switches for the individuals window works. Also, the green light on each switch blinks slowly. All locks and side mirrors controls work on the master driver switch.
Any suggestions?
Any suggestions?
2IS OG
The stickied FAQ/DIY thread should be your first stop for these types of questions. In there, you'll find this thread (along with many others) that will provide the answers you seek. The reinitialization of the power window switches is easily one of the most "frequently asked questions" on this forum. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Javier
Javier
