Is there a list of all TSIB for a 2006 IS350?
Assuming they do the engine rattle TSIB, will I get a free oil change?
Also with the steering recall, will they do an alignment?
Try threshold braking on ice, or another low-friction surface, and watch what happens. Aside from the ABS kicking in (which kinda proves the point), you'll find that your brakes stop the rotor perfectly fine...and yet your stopping distance is longer, because your tires can't find the grip/friction to slow the moving vehicles motion.
If you want to slow the vehicle faster, then you must start with the tires. Once the calipers lock the rotors, and the wheel stops moving, you're only going to slow the car so fast as your tires can afford grip.
I just had a steering link assembly changed under recall.
its says
8613CH 9LC Replace Power Steering Link Assm For IS250/350
And now my car does not steer the same. They've aligned my car twice but above 60-70mph, the steering rack has a slight stuck feeling when making small corrections to the left. Nothing dangerous, but it feels like the magnets are sticking or something.
I'm going to put some miles on the car before I complain again.
its says
I have synthetic oil, will there be an issue if they just mix in regular oil and dont do a full oil change?
