DIY Changing Stock HID Bulbs
#91
If you go with an HID kit for your fog lights than yes you need a ballast and bulb.
Honestly 6500K and 6000K are essentially the same as there would be no visual difference.
What were you looking to get out of your parking lights and turn signals by upgrading them?
Danny
Danny
#95
Scatter pattern
Thanks for this great tutorial. Changing the bulbs was extremely easy. I have one issue now though.
Now that the bulbs have been changed, I'm noticing the scatter pattern of the light is uneven. I can see linear streaks coming from both headlights, rather than the normal, soft, and even dispersal. I can only assume it's some sort of alignment issue but I'm not sure what needs to be done to fix this.
Anyone have any suggestions?
#96
#101
Pdf
Could you send me the pdf please thanks
Awesome Post bro...I never realized all that stuff came out on the drivers side...I've been squeezing my arm in between all that crap.
Anyways i compiled all your pictures and directions into a PDF...mostly for my own use (lots of times the pictures go missing from these threads)
If anyone wants that let me know.
#103
Ooh can I get a copy of ur pdf with instructions and pics?
Hi can I get a copy of your pdf with instructions and pics? Not sure how often you check these threads but if do do, mugetteahn2@yahoo.com. Many tkssss!!!
#104
Or, here's a video.
#105
Thanks for your response back! Does the video and quick review by you of what to expect in changing out the headlight bulbs also apply to a 2016 Lexus RX 350? I couldn’t find any videos or instructions other that I found thru this platform on even what type of led bulbs to bulbs I can upgrade to. Is it a conversion kit I have to buy and what exact kind is compatible with my car? I’ve bought at least 3 different leds headlights on Amazon and places online that were supposed to compatible but they turned out not to be. I could only find high beam bulbs, side marker bulbs or fog lights bulbs but no headlight low beams bulbs. I’m so confused. Will these instructions work with my car and can you suggest what brand or type of led or other headlight low beams bulbs that is compatible w my car to replace with. Even the car manual shows nothing!
thank u!!!!!
Or, here's a video.
[/QUOTE]
thank u!!!!!
Or, here's a video.
