DIY Changing Stock HID Bulbs
#106
Thanks for your response back! Does the video and quick review by you of what to expect in changing out the headlight bulbs also apply to a 2016 Lexus RX 350? I couldn’t find any videos or instructions other that I found thru this platform on even what type of led bulbs to bulbs I can upgrade to. Is it a conversion kit I have to buy and what exact kind is compatible with my car? I’ve bought at least 3 different leds headlights on Amazon and places online that were supposed to compatible but they turned out not to be. I could only find high beam bulbs, side marker bulbs or fog lights bulbs but no headlight low beams bulbs. I’m so confused. Will these instructions work with my car and can you suggest what brand or type of led or other headlight low beams bulbs that is compatible w my car to replace with. Even the car manual shows nothing!
thank u!!!!!
Or, here's a video. https://www.youtube.com/watch?v=DTJvWlKfaLI
thank u!!!!!
The 2016+ RX350's do not use user serviceable low/high beam bulbs because it's an LED diode built into the headlight assembly. If your low/high beam is out, I would check any fuses/relays as your only options are to check those, or replace the headlight assembly. The only bulbs that can be changed on the headlights are the turn signals and the side markers. Fogs are LEDs that also are not user serviceable.
madchyers
IS - 1st Gen (2001-2005)
19
07-06-23 02:13 PM
