LED modual
do i just need the led modual from v-leds with just my drl led bulbs and not my city/ parking led lights or do i need one for both? I have no idea whatim doing with these. i did search but wasent clear on this!
Just in case you missed it, look here. It should answer most questions for you and is VERY helpful.
https://www.clublexus.com/forums/is-...ting-mods.html
Now, here's a quick summary. If you want the white look for DRL then switch it out with LED but you'll lose high beams. If you change the bulbs to PIAA xtreme whites, they will still be yellow for DRL due to it being on at half power. The parking lights are the ones in the corners, and those only comes on when you are parked. Both of them gives a yellow hue when on. I am not sure what you are asking so I can't really answer your question fully.
from what i have heard you need a moduel that plugs into the led bulb for your drls that prevents it from flickering or something. is this right? if so thats what im talking about!
Yeah, the 168/194 are for parking/city lights. The 9005s are for DRL. The direct replacements or the module would work. The module is to not have the LEDs at half power since that is not necessary. It gives the LED full power for DRL or high beams if I remember correctly.
