/volk progressive spoke 1 piece forged aluminum
can this fit my car? is250..
i am dropped on tananbe's and i dont want to do any fender mods and be able to make full turns.
VOLK PROGRESSIVE SPOKE 1 PIECE FORGED ALUMINUM
19-8.5J +22 OFFSET 5X114.3 (FRONT)
19-9.5J +25 OFFSET 5X114.3 (REAR)
just me being a noob, but how exactly is cutting the fender done? is it simple as getting some tool to cut that metal fender? If it is wont it become quite sharp and ugly looking? someone enlighten me. Im in the process of looking into a fender mod for my rears.
Thanks
Thanks
I have LE37 with a +22 offset front and rear, and I can tell you that you will rub up front, you'll have the use the heat gun the melt the plastic in, and in my case I had to cut off the corner of the side skirt on the inside because it was rubbing, and in the rear you'll have to cut your fender, you can use a dremel to cut it, you will hardly notice that it's cut once you've cut it.
JUST DO IT.
go lakers
