IS350 19" fitment questions
I have an IS350 lowered on F-Sport springs and I'm about to pull the trigger on some new rims/tires.
I'm looking for a nice flush setup with no rubbing, but the whole tire size picking thing baffles me.
Front: 19" x 8" +35 in 235/35/19
Rear: 19" x 9.5" +45 in 265/30/19
Will these offsets fit properly and work with those tires?
NO NO NO NO NO.
if you must use 19x8 and 19x9.5 and those tires, then get
19x8 +30 with 235/35/19
19x9.5 +35 with 265/30/19
but you're open to all sizes and want to use fat rubber use
19x8.5 +30 with 245/35/19
19x9.5 +30 with 275/30/19
and if you want to very aggressive with not-so-fat rubber, then use
19x8.5 +20 with 225/35/19
19x9.5 +250with 245/35/19
The thing is the wheels I'm looking at are only available in 19x8 +35 or +45 and 19x9.5 +25 or +45 but I have no idea which would fit best and what tires to use.
Could I do 19x8 +35 in front with 245/35/19's? Will these clear my brakes?
get the 8 +35 fronts and 9.5 +25 rears. run tires sizes 225/35/19 and 235/35/19. you should be ok with that. and if your brakes don't clear, then just add a 5mm spacer and you should be fine.
