Will a 245/40/18 tire fit my rear wheels?
Old 06-01-09, 10:54 AM
carrwash13
carrwash13's Avatar
Default Will a 245/40/18 tire fit my rear wheels?
Will a 245/40/18 tire fit my rear 2IS wheels? 255/40/18 seems to have way fewer choices and the price jump is pretty significant. Could any potential problems occur?
Old 06-01-09, 12:18 PM
Byprodrive
Byprodrive's Avatar
It will fit your wheel but over the life of the tire will cost you more in reduced gas mileage & increased mileage acumulation on your odometer.
Always think of the cost of tires for the duration of the tires life. More expensive tires tend to last longer ( cheaper to use)
there are plenty choices in 255/40/18 check Tirerack.com to see whats available, then call local stores to compare
Old 06-01-09, 02:05 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
or try 265/35/18
Old 06-01-09, 03:27 PM
acefalcon2
acefalcon2's Avatar
just stick with it...
Old 06-01-09, 11:38 PM
juice14
juice14's Avatar
if you get those you better be dropped, the fender gap will be even worse than stock.
Old 06-01-09, 11:50 PM
mvlbr
mvlbr's Avatar
You should be fine considering that the stock 17" package comes with 245/45R17 has the same overall diameter as a 245/40R18.
Ken167
02-11-18 02:02 PM
hohohong
12-03-15 07:13 AM
98supra6sp
SC- 1st Gen (1992-2000)
11-18-09 10:54 AM
lok214
Wheels, Tires & Brakes Forum
02-08-09 12:39 PM
gassman
06-26-07 08:56 PM
Quick Reply: Will a 245/40/18 tire fit my rear wheels?
