DRL replacement bulbs..need help!!
So i already have stock HID lows, about to upgrade to the Garax 6000k bulbs. But i'd like to change my ugly yellow DRL bulbs which i understand are my high beams at a lower voltage or whatever. I was doing a search and saw people were buying HID kits for their DRL, but since i already have stock HID's i would only need to change the bulb correct, or is the HID only for my lows?? Anyways i keep reading about V Leds or something but alot of people are having problems with them going out. Bottom line is i just want to get rid of the yellow, but i dont want them turned off.
Yes,just like they said above.You will lose the Highbeam if you go with LED.The other option is you can find the PIAA Bulb Super Plasma that will delete your stock ugly yellow and give you a white DRL ( almost white ) light at the half voltage.
http://piaa.com/Bulbs/Bulbs-9000.html
I hope that will help your question.
Thanks...i've been reading that the v-leds are having problems with flickering or going out though. Does anyone have any pics of DRL's with only replacement bulbs in there without a kit??
Hey sorry its been a couple weeks but i went to order the V-Led kit for my DRL's but they are sold out,,,any idea of anyone else with a kit like this, i need to get rid of these ugly yellow DRL's and i like the look of the kit from V-Led
I'm running the v-led kit and I couldn't be happier with the output as a DRL. The kit basically eliminates the flicker of the led by running the correct wattage to the bulb at all times. I can try to post a picture but I'm sure others have already posted pics in the lighting thread. If you like the pic on the v-led site you won't be disappointed =)
I've seen pics and i really like it as well, problem is they are sold out right now on the V-led website. Thats why i was asking if anyone knows a different website to get these from or a different kit that works and looks the same.
PNice972
06-10-06 03:23 PM
