What do the Navi Service menu error codes mean??
For anyone who doesn't know, to get to the menu, you hold the Info button while switching your headlights OFF->ON->OFF->ON etc... You have to do it about 4 times or so.
My question is if anyone knows what these error codes mean.
1st Picture: The screen that first comes up when you do the steps that i mentioned before
2nd Picture: The screen that shows the errors when I push the DSP-AMP "CHEK" box
3rd Picture: The screen that appears when you go back to the main service menu and select "LAN MON"
4th Picture: The error codes that show up when i press the NAVI "CHEK" Box
Does anyone know what they mean? The two items showing up as errors are the same two items that broke when my car recently had flood damage.
Thanks
Thanks
i dunno, but this happened to me after i disconnected my battery and removed the fuse for tv1. i kept clearing the code and removing the fuse and eventually as i was drivign one day, everything started working. if you removed the nav disc or something like that it takes like 30 minutes for the system to reload everything.
