JDM yellows in the DRLs
#47
Danmmm
I'm Dreaming
I see yellow everywhere
How hard is to replace the DRL does someone have DIY
love67 are you getting those Nokya w/ harness
love67 just found out ebay selling it, and it comes with the harness too. but do you guys think the harness is strong enough? should i use it or just buy the nokya's harness?
http://cgi.ebay.com/ebaymotors/9005-...5%7C240%3A1318
#48
and im still thinking to get the ebay one, but im worry that the harness is not strong enough because it doesn't say that harness is also from nokya, so maybe i will get the nokya's harness as well....however the nokya's harness is expensive, it's like the same price as the bulb.....
i will see. and you ?
#49
i dont regret getting the nokya for both DRL and FOG.
the fogs are awsome and are really yellow.. alot of people ask me if they are HID Fogs..
my high beams on the other hand is literally like a Gun for tailgaters who pass me.
i hit them with the HARDCORE yellow and they tripp out.. its really really bright
im on stock harness
Cmon guys.. just get a 2nd harness just in case.. its like 6 bucks at NAPA i know this,.. i used to work there when i was in highschool. :P
#50
i also am going to order overlays... for the yellow look when the fogs are not in use.. its looks hot and sexy like a japanese girl with Razzy glasses..lol
sorry im just a nerd. and a sucker for japanese girls.
#51
also i had yellow 194 for the PL my friend convinced me to get the 4SMTLED.. in White..
i didnt like it.. it made the car look cheap. i gotta find the pics from when i had the yellow ones in .. and yes im going to put the yellows back in...
its way sexxier x100 lol
#52
it's just plug and play? just open the box( non- HID ), turn the bulb out and put the new bulb in.
Push down on the centre of the tabs then they will come out.. do not pry on there unless you push the center part of the clips or you will break something..
...unscrew the cap that covers the bulbs (philips screw driver..) in this case a flexy neck philips screwdriver would be handy)
unbold the washer fluid filler neck .10MMsocket.
unplug the harness by pressing down on the tab and push down.. you may need a flathead screwdriver to assist you in "pushing in down" it can be a pain in the backside... take off the snorkel, airbox and disconnect the MAF as you would need to bend the flexi hose back and need clearance.
after the harness is disconnected just turn the bulb upwards to the left 1 half of a turn and viola... put everything back and bomb your good to go.
Tools needed.
10MM socket w/ Ext piece.
Philips head screwdriver flexy neck or stubby
#53
Have you tried out the high beams, do they diminish the output as compared to stock? and 80w.. is there a required harness changed? I am noob to this and high beam is important to me since over here east the government like to leave most of the roads, even major highway without any lights at night lol
Sorry, just saw this No harness change (as you've seen in this thread already I'm sure) and no change to high beams, at least not for me- Still bright and blinding as ever =)
#54
ok, i think i have been convinced...nokya hyper yellows in the fogs and drls it is. i'm most likely buy 2 sets of heavy duty harnesses (for peace of mind).
is there enough room to maneuver to install the harnesses in the fogs? from the DIYs ive seen it looks like a pretty tight fit and you're doing it blind on the drivers side...
#57
http://cgi.ebay.com/ebaymotors/H1-No...5%7C240%3A1318
which one is the real deal?
