View Poll Results: IS350 owners ONLY -- Engine rattle at startup TSIB
My IS350 has never had the issue.
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
24
21.82%
My IS350 had the issue but the TSIB fixed it and it has not returned.
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
25
22.73%
My IS350 had the issue and I had TSIB done but the problem returned.
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
16
14.55%
I have the rattle issue but have never done the TSIB.
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
45
40.91%
Voters: 110. You may not vote on this poll
IS350 Engine rattle at on startup TSIB
Well the current stats are showing about 75% of IS350's have this problem... that is pretty disappointing from a quality point of view. If we were driving a Sunfire or a Cavalier I could understand but a 75% fail rate on a Toyota (even worse that is it their higher end Lexus) is just not acceptable IMO.
IS250 doesn't have this issue I would assume.
Every manufacturer has their defects.
I am curious to know if there are any long term negative affects of this problem. Will my engine fall out of my car in x # of miles...
If it's not an issue than I'd rather not visit the dealership only to be disappointed, as I am now...
I can't think of any other 'luxury' cars that make a grinding / rattling sound loud enough to turn heads when you start up. Yes every manufacturer has defects but this ones is pretty bad and it seems they have no permanent fix for it since even 2008's have the issue...
I am just worried that I am suppose be getting it fixed, but in reality they are just 'patching' the problem and it will just resurface in a year or two.
I don't feel confident that they have solved the issue at all.
I will say, though, that my dealer has been 100% on top of this problem any time I've had questions, complaints, etc. about it, which does represent the brand well in how they address problems that undeniably do and will exist.
I am getting it fixed next month. Currently the temperature outside is hot so I rarely hear it (haven't heard it in about 3 weeks). But in the winter I would say I hear it every second or third startup at all times of the day.
It's embarassing as your car sounds like it's got serious issues. I haven't had even 1 passenger NOT comment on it when they heard it.
So I'm kind of curious. Does anyone have a 2010 IS350 that has this issue? It seems that people are getting this as early as 20k miles, so I'm curious if they've fixed it in later versions of the 2IS.
