Your car is under warranty, suggest that you keep working with them.
I tried everything. Talk to the rep, manager, then they called warranty services and they said this part is not covered. Well i decided to remove the grommet myself since that is was is causing the problem. I just lowered part of my transmission and looking for the grommet to remove. If anyone has an idea on how this thing looks it will greatly be appreciated.
Did you look at the TSIB here? It shoulds everything that the dealer would do.
If there is a TSB and your car is still under warranty, I believe the dealers will fix it per the TSB. Did you try printing out the TSB and showing them?
Naw. Its my only day off from work and i am TRYING To remove it myself, but i cannot find the damn thing. I followed the TSIB and no luck. On a RWD where does the ac water usually come out under the car.
Hm..The a/c drain plug could be plugged with rat crap, and everything else that flies in there. Jack your car up and use a metal clothes hanger and stick it in the hole.
Hey guys am new but am a lexus sensor tech if the car is still under warr. 4year or 50mile what ever comes frist its free if not all you have to do is go around the front of the tranny up top and remove drain plug warrty. is not paying to remove dash any more so dont pay for that its bull****
hmm after reading the TSB, all I see is that they remove some kind of plug from underneath the car. Where does it state that you have to take apart the dash and replace with newer stuff?
