i want to do the retro fit for my fogs but cant find the projectors
Old 06-13-09, 11:27 AM
DJSirkit13
DJSirkit13's Avatar
Default i want to do the retro fit for my fogs but cant find the projectors
i want to dot he HID retrofit for my 2IS but the Bosch mini H3 projectors are not available anywhere i searched all over.
can anyone help me find them or has a pair they want to sell that would be great
and if you have another alternative set of projectors that may work please let me know
Thankyou
Old 06-13-09, 11:39 AM
ELL Y
ELL Y's Avatar
PM me tonight. After work I'll get the email address of the guy who sells em and has tons of them.
Old 06-13-09, 12:14 PM
ExTrEmE99
ExTrEmE99's Avatar
Anyone want to do a retro for me?
Old 06-13-09, 12:55 PM
DJSirkit13
DJSirkit13's Avatar
if someone is willing to do the retrofit for me that would be nice but dont mind doing it myself and did anybody try puttin leds in the fogs cuz paying 2gs for the jdm ones not worth it.
Old 06-13-09, 03:26 PM
jns350
jns350's Avatar
you should also PM Tchan1....he did his and it looks really good. I've hinted at him doing it for me also....Master Chan !!!!...but he said it just took time and was not that hard to do.
Old 06-13-09, 09:33 PM
ELL Y
ELL Y's Avatar
The hardest part IMO is retaining the stock adjustment screws by using the existing reflector and mounting the projector onto it. It makes it a very tight fit. However, if you can devise another method of vertical adjustment (as well as rotational, which is a ***** to correct if you mess up the first time), you can fit a wider variety of projectors.
Other than that, it's a bit of cutting here, a bit of cutting there, etc.
Old 06-14-09, 08:13 AM
iSuxeL
iSuxeL's Avatar
Why not use the FX35-R? The output is so much better than the mini Bosch.
Old 06-14-09, 09:34 AM
Tchan1
Tchan1's Avatar
It's way too big to fit. But I guess it's possible if you really wanna do it. Lots of cutting and fabbing up though.
Old 06-14-09, 11:18 AM
iSuxeL
iSuxeL's Avatar
Another member already did it.
Old 06-14-09, 05:34 PM
eskae3
eskae3's Avatar
I used the FX-R Projectors...and yes it is a lot of work to make them fit. The tolerances are tight once you get the bumper on. They practically touch the sound dampening behind the fogs. Might be easier if you want to go with the mini bosch if you don't want to go that extreme.
I like how the FX-R fits the whole original shroud opening and you don't have to use a plumbing shroud like others do :-P
Old 06-14-09, 09:41 PM
Tchan1
Tchan1's Avatar
Just wondering why you are using a bi-xenon projector for it? Just curious..
Old 06-14-09, 09:58 PM
ELL Y
ELL Y's Avatar
He has them aimed up as high as his regular headlights, so the bixenon functionality can still prove useful.
In addition to being a tight fit, it is difficult to adjust such large projectors. for the sake of the function of fog lights (lighting up road edges and increasing foreground visibility), a properly aimed Bosch Mini, though inferior to a projector like the FX-R, is perfectly fine for a fog light. Remember, fog lights are not meant to supplement your vision down the road- it just often happens to be the case with HID kits which spray the light all over the place.
Not trying to rag on ya Eskae. Hell, I'm even considering using a tsx or other projector to redo the fogs, but my headlight retro is incredibly bright as it is, so I'm still deciding.
Old 06-14-09, 10:06 PM
Tchan1
Tchan1's Avatar
If it's aimed up that high, it would blind people wouldn't it? Because the fogs are at the bottom so the beam would slant upward.
Old 06-14-09, 10:11 PM
istundra
istundra's Avatar
yes. it will blind on coming traffic due to the angle.
if you want to retrofit it, i'd go with a HID projector.. not minibosch cuz those are H3 halogen projectors.
istundra
istundra's Avatar
Quick Reply: i want to do the retro fit for my fogs but cant find the projectors
