Technical Data on IS250/350 front brake
In 2006, I have asked the same question to a connection in my local dealership..
I dont think there is anything like that officially from Toyota or Lexus.
Are you trying to fit it onto another car??
Good luck
Good luck
I am trying to find a way to do a custom BBK for normal daily driving use by getting calipers separately from BBK manufacturers. Hopefully this will cost as much as IS350 caliper conversion while giving you an aftermarket look, without messing up the brake ratios.
Maybe this can start something for us 250 guys without a balling budget for BBK setups
I know about the 350 conversion. I am asking about the brake technical data.
If I can get aftermarket 4pot on for the same cost as the 350 conversion (4 pot as well), I would prefer the aftermarket look to be honest.
So I guess no one knows anything about this? Hard to calculate the braking force without any data lol.
Does anyone know the dimension of the IS250 front rotor? whats the diameter x thickness in mm or in?
