New IPOD interface in IS-C ?
If the USB system in the ISC works the same as it does in some other cars that I've hooked into, its a pain. I have had a rental Taurus, & Sonata that both had USB hook up's. I hooked my iPod into the usb and it read it like a hard drive. The system in the car looked at each folder and then played the music out of that folder. In both the Taurus and Sonata, it did not display song titles or anything like that, just odd coding names that iTunes names the music. I was not at all impressed by the USB systems in either car. Hopefully I was just using the wrong, but if not, I'd rather hook it up through the miniplug aux jack.
You're in a car, constantly hitting bumps, vibrations go through everything, including that hard drive. hard drive = too many moving parts, something is bound to go wrong, heat, worst case scenario that the needles touch the spinning platter causing it to become inoperable = lexus charging you quite a bit of money to replace that unit, which is probably going to be more expensive than the navi for our cars ($2500+).
I think if they sway in the direction of SSD, now that would be latest tech.
I think having an HDD based navi isn't smart what so ever.
If Lexus could improve the nav systems that are currently used in the IS line, it would be huge. The Lexus system is so far behind what the other luxury manufacturers are offering in their cars (Infiniti, Acura, MB, etc...).
Other car manufacturers are using HDD systems and have been for a couple of years. I haven't heard of any major problems with a HDD system as of yet. I currently have a HDD nav system and have had it for 2 years- no problems yet. I have put the car through a lot and it has held strong and given me no problem.
I've been working at a data recovery company for three years now, and i've seen atleast 3 drives from Cadillacs that were so gone that our engineers had a laugh for a good hour. I'll try to find pictures of the drive.
I agree with you that they need to improve their tech, a $99 TomTom has more features!
Or if Lexus really wants to be ahead of the pack, they can offer a SSD instead of HDD. Or they can engineer a HDD dock in the trunk area for easy access and we can make an image on our PC's to back up the info, that way when the HDD goes bad, it'll be an easy swap and play.
Better yet, I'll patent it and then sell it to Lexus
SSD technology would definatley be awesome, however I don't see Lexus introducing that technology into their cars until someone else has tried it and it works. Lexus/Toyota is too conservative a company to try something like that.
With HDD's it's not IF they are going to fail, its WHEN.
But more important we are getting off the subject of this thread, I posted to see if anyone knew more about the IS C's new IPOD interface.
Sure, no problem, however when did they start using HDD's? Two years ago? Average HDD has a life cycle of about 1,000,000 read and writes, i'm going to guess we are going to see some failure soon.
I didn't compare GM to Lexus? I'm comparing hard drives.. what did you think since Lexus is a super luxury brand it will use super luxury HDD's? If that's the case, you are terribly wrong. All hard disks are the same, all of them fail, and i personally believe that having something with that many delicate moving parts in a moving vehicle isn't smart. SSD = no moving parts = will run forever.
Sorry I don't agreed that all hard drives are the same, there are different specs and a big difference in the way the hard drive is installed and supported. I work for Harris Corp and all our equipment is Military-Grade now I am not saying Lexus uses Military-Grade harddrives, but since GM tries to cut costs at every corner I wouldn't be surprise if they cut corners on the way the harddrive is installed verus the way Lexus installed it. Just my 2 cents.
I believe audio brand Eclipse has a 7" DVD/Nav unit with SSD built in, if they can do it, Lexus can as well.
Sorry about steering so far off subject.
Super Moderator
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Small ruggedized hard drives have proven themselves in other applications. Most of the older and larger iPods are HDD based, and people run with them, jog with them, drop them, etc. Lots of technology to survive rough environments is baked in - heads park when not in use, shock sensors retract heads or move them to a safe zone when impending impact is suspected, special platter coatings and lubricants minimize damage should head contact occur.
SSDs will no doubt be developed for automotive applications, but until they are, I wouldn't be overly concerned about the durability of HDD based units.
Isn't this the same Nav and usb connector that is also available in the new 2010 RX? So I would suspect it works the same in by of those cars.
So it has now moved from the LS to the RX and down to the IS-C and most likely coming to the HS250.
