168 DRL parking light??
I just recently bought the PIAA extreme white 168 bulb for the drl parking light in the head light. Its the tiny bulb in the upper right corner where the drl/high beam in located. Im not happy with the bulb I got because its showing up as a bright blue and my HID's headlights and fogs are white. I feel it looks kinda ricey...
My questions is if I put a LED 168 bulb in their to replace it will I lose my High Beams? I know if i replace the actual 9005 drl/high beam with a LED I will lose the high beam option but what it I just do it to the 168 parking light?
Do you have pics of 168 PIAA bulb? I thought PIAA Xtreme White was a white bulb in color, not blue? Is it that blue in color?
also just to clear up some confusion the drl is the high beams they are not the parking/city lights.
correct... your high beams (9005) are also your "day time running lights" (drl) the only difference is that they are run at 30% power during the day. your "city lights" is the small 168 bulb you're referring to that sits in the same housing with your high beam... they have nothing to do with each other
No u will keep your highbeam because you didnt get a LED. If u are looking to match the factory hit or even get a white look for your DRL take them back. I have them and I love them but by no means are they white or do they match the low beam. They are less amber than factory and the highbeam is very bright
johnnunez2
11-02-10 07:14 AM
