Will the ISF hood fit the IS250/350?
I was just looking at some of the dimensional specifications for the ISx50 and the IS F and it appears some structure under the fenders is different, but honestly without trying to fit it, I don't think you'll get a definite answer.
Go to a dealer, make some measurements, lol.
EDIT: It looks like the bolt holes are definitely wider on the IS F and there are some other differences. More than I expected; but that doesn't necessarily mean the hood won't fit.
Jeff
Jeff
The only way to fit it is get the appropriate ISF parts to make it fit. If you are doing a front end conversion there will not be much more you need to accomplish this task. I did look into it before the Fox Marketing ISF was crushed as I wanted to switch hoods with him but it was not a bolt on application so I could not do it.
