If you wanted to make the wires exiting the housing less, you could have solder the leds in parallel or series. Recalculate the right resistor and solder some wires instead of have a whole bunch coming out of the housing.
LED guide in this LINK
Only if I knew anything about what you just said. lol.
damn Tommy...that is so cool. Now I feel my turn signal dual changing light mod is old news compare to your fog retro and led insert mod. I'm glad your local so I can check this out.....when you coming over next time??? can't wait.
Haha, nah your changing light mod is still sick. I don't even have it. When is the next meet? I won't be at BOS cause I am going to be away for training during that time, leaving this Saturday actually.
Originally Posted by yayitscola
wow...so um how much you want to charge us local people to do this project
Haha, I'll see, or I can just guide you...right? I wasn't planning to charge people, but I'll see how many people wanna do it first.
Originally Posted by Phanatik
That is damn sick! But I don't have the ***** to do that project. Where are you located again?? haha.
I am located in Norcal, Oakland
Originally Posted by fluxx
ahhh someone beat me to this. i was in the middle of working on this. looks great bro! would you mind take some pictures when you get it mounted on the car and possibly some pictures that are a little further out.
you could of used these holders though to keep the led's in place.
Yeah I've seen that on ebay. But it looks a little too big. If I use that I won't be able to fit that much LEDs on there.
Originally Posted by ExTrEmE99
Very Nice! I thought about this, but using the circuit board led construction.
Any photos of the LEDs installed just not turned on?
Yeah having a circuit board is much cleaner and simpler, but I have no idea how to mess with it. Plus its kinda of hard to fit a circuit board too because that part of the shroud is curved.
Originally Posted by rs/ss
Well done.
I would also like to see front view of leds installed but without power. How do you remove the projectors? Looking forward to pics :-)
For the ones who wants to do the mod that turns your fogs on without the headlights being on you can use this harness. All you need is to get a switch for it like how I did for the LEDs. Unless you want to use the tacky looking switch that is provided with the wire harness.
All you have to do is connect the ends to your power and ground wire that connects to your ballast ( If you are running HIDs). For the ones who aren't using HIDs for fogs. Just purchase 9006 female connectors and connect to the end of the harness and plug it into your bulbs and you are good.
