My first wheel scratch... Only 1 day into owning the IS350
#32
ahh yes the advantages of buying a used IS 350. That is true the curb rashes does not hurt as much as it would on a new car.... I bought a used IS 350 n it came with curb rashes free of charge. can you believe that?
2009lex - its cool. 700 was just a bit unbelievable. 875 is close to 700 i guess. its the darn new math that is beaing taught in school these days =). i missed out on those classes.
#33
Some Drilling Required
I've owned three cars with low profile tires and alloy wheels. Either learn to give curbs and those nasty concret wheel stops on parking lots some room or try these
Seriously, careful use of the right side mirror works. I feel your pain.
On the cheap I've had good luck with using a sharp chisel to scrape down some the the ridges and some fine abrasive to clean up the small scratches. Touch up paint that is close is usually not too noticable on wheels (under the brake dust and splatter).
#37
Are you seriou, you adjust your mirrors every single time you parallel park your car? That's a bit excessive don't you think? But then I guess it matters on how often you parallel park you car.
tracerit
Wheels, Tires & Brakes Forum
10-29-08 10:27 AM
