Gas brand and octane discussion (91 vs 93 or above)
Old 07-16-09, 12:04 PM
  #31
Byprodrive
Byprodrive's Avatar
Originally Posted by GQD_GS4
+1...strange but true on my rx400h
try some E85 or Gasohol for some really bad MPG
Old 07-16-09, 12:10 PM
  #32
Kurtz
Kurtz's Avatar
Originally Posted by Byprodrive
You don't think a IS350 will dial in more timing advance for 93 over 91?
Nope. If it did that then it would recommend 93 in the owners manual.
The car has -no idea- what kind of fuel you put in it, so all it can do it run the normal max timing it's programmed for, which should correspond with no knocking at 91 octane for the 2IS, hence the 91 octane requirement.
Old 07-16-09, 03:28 PM
  #33
Lexus@17
Lexus@17's Avatar
soo lets put this out there...
chervon is a better quality gas compare to shell?
or it really just dont matter at all?
Old 07-16-09, 04:48 PM
  #34
J_Hao
J_Hao's Avatar
always the shell....
Old 07-16-09, 04:49 PM
  #35
Kurtz
Kurtz's Avatar
Take three ISx50s brand new. Run them for 50,000 miles- One on only Chevron premium gasoline, one on only Shell premium gasoline, one on whatever random name brand of premium (same octane) fuel happens to be nearby whenever you need gas.
Now take the engines apart.
I'd be very surprised if you could find any measurable or significant
difference.
(the above assumes none of the station owners, who are generally independent and just pay for the name on the station, waters down his gas or does anything else shady, which'd be just as likely with one brand as another)
Old 07-16-09, 04:51 PM
  #36
panda327
panda327's Avatar
gas is gas .. there is no better quality gas.. only difference u'll see is the additives in the fuel
just fill whatever you think you "feel" better after putting in ur car and stick to that ... aslong u stick to known brands of gas . ur car will be fine .. i never heard or someone filling their car with fuel and have their car ****ed up
Old 07-16-09, 05:15 PM
  #37
isFiend
isFiend's Avatar
As long as you go with big name brands I agree, chances are your car won't necessarily **** up.
I've just seen so many positive reviews about the additives that Chevron puts in versus Shell's additives that for me (given how convenient it is for me to fill up on either Chevron or Shell, it's my choice) going with Chevron just makes sense.
Of course I'm not going to go out of my way just for Chevron if I'm running low, but if it's convenient and I have the choice, why not
Old 07-17-09, 05:41 AM
  #38
Koz
Koz's Avatar
Shell's cleaning additive is nitrogen enriched. It is a key element of the active cleaning molecule in Shell’s new fuel (March of this year), supposedly making it significantly more stable at higher temperatures which is common in modern direct fuel-injection gasoline engines. The increased stability ensures that the molecule can work under much tougher engine conditions by resisting thermal breakdown better than conventional cleaning additives. This new formula is supposed to have five times the cleaning power of fuel with the EPA’s minimum requirements. Is it better then Chevron's, time will tell!
Koz
Old 07-17-09, 10:13 AM
  #39
Byprodrive
Byprodrive's Avatar
When I worked at Shelby American I took a Series 1 to the GM Proving grounds in AZ for emissions compliance development, the engineer in charge said to be sure & fill the tank with Chevron Premium 91 octane minimum. This was in 1998.
The other factual reason I use Chevron premium in my cars: I bought a 1986 Prelude SI new used Chevron (regular for this car low compression) used Shell a couple times noticed Idle speed began to fluctuate. 2 tanks of Chevron cured idle problem, wife refueled with Shell idle problem returned, Chevron fixed problem again. I assume Shell has fixed that problem in the last 20 years but I believe Chevron is as good or better than any other fuel other than maybe Amaco. I am confident that there are many brands & individual stations where quality control is not up to Chevron standards. I have discussed this with a chemical engineer who designed & setup several refinerys here in So.CA & around the country (all brands ) he only buys gas with his Chevron card. I lived in Manhattan Beach for 10 yrs. across the street from the Chevron refinery which has been there since 1914 & went on the annual tour of the refinery. Chevron costs 3 - 4 cents more a gal. but why gamble with the unknown ??
Old 07-17-09, 10:26 AM
  #40
Koz
Koz's Avatar
I wish I could try Chevron, can't get it in NJ!
Koz
Old 07-17-09, 11:15 AM
  #41
Phiber
Phiber's Avatar
Is costco gas clean? I read a article and said that costco gas is nearly on par with chevron/shell. Not sure if it is true or not.?
Old 07-18-09, 10:22 AM
  #42
rebs
rebs's Avatar
It might be clean, but the additives are lacking. Our Costco is filled up by Flying J.
GoGiantsNJ
03-10-13 05:27 PM
LexLuger31
14
07-19-11 08:05 AM
jasone36
02-15-10 03:28 PM
adc
05-06-07 05:50 AM
jimjaix
03-08-07 10:01 PM
Quick Reply: Gas brand and octane discussion (91 vs 93 or above)
