Maintenance questions for IS350
I am about to be in need of an Oil Change (10k miles on the odometer).
Just wanted some peoples opinions on where to get it changed at. Should I just ***** up and get it changed at the dealership? Is there any benefits of getting it changed at the dealership? What kinda prices is everyone else looking at? I was quoted $85 from the Lexus dealership. Does that sound about right? It kinda seems steep to me.
I read somewhere that I should rotate my tires too but how can you rotate the tires on a car that has two separate sized tires?
What really needs to be done at this 10k mile oil change?
I have the summer performance tires on this car and I was told that they only last 15k miles. I would expect closer to 20-25k. I do not drive the car hard and do not peel out. The current tires look like they have have a lot of tread left. I know it is at least one oil change from having to change the tires but how much would it cost to replace the tires if I wanted to stick the same OEM tires on the car?
I have looked at the users manual but not 100% if everything they recommend is actually needed.
If anyone can kinda give me a quick run down on what they usually do to their cars I would appreciate it.
For ease of records, positive resale/trade-in impressions to the dealer, and convenience, the dealer isn't that bad of an idea. You know you are getting Lexus products and the job should be done cleanly and correctly (hopefully). For me, it's worth a few extra bucks. Plus the Lexus loaner allows me to tool around elsewhere and test other Lexi. Just a thought.
If your car is new and still under warranty, you DO NOT want to go a year without an oil change regardles of type of oil. Lexus states every 5k miles or 6 months, whichever comes first.
If your out of warranty, do what you want.
Again, if still under warranty, you need to follow the users manual to keep from voiding the warranty. If you should have to file some sort of warranty issue in the future, you can bet your *** they will look at maintenance records to see if you've adhered to the recommended guidelines.
One note though, dealers will recommend more things than what is in the manual. Just stick to what the owners manual says.
If you are using quality synthetic oil you will not have any problems with oil related engine failures or your warranty. Most quality synthetic oil manufactures will even supply documentation to help you if it comes up. The bottom line is the manufacture will have to provide a UOA that shows the oil caused the failure. This is NOT going to happen!
Koz
Oil changes as appropriate (probably 1/yr for synthetic, 2/yr for conventional)
Every 15k: Change air and cabin filters- You should be doing this yourself, it takes 5 minutes.
Every 30k: Change brake fluid
Every 60k: Change spark plugs
Every 100k: Change coolant
That's -it-
That's also why you should never ask a dealer for the "X miles" service- they'll do as above plus jack the price up 3x higher for a bunch of "inspections" that they'll do for free anyway if you just have the stuff you actually need done.
Completely false. Federal law prohibits them denying warranty coverage for anything you do aftermarket unless they _prove_ that what you did causes the failure.
Which won't be the case with 1 year changes using a good synthetic.
Amsoil in fact -guarantees- their oil is good for 1 year/25k miles.
I have a question about oil change. The Lexus oil change sticker says I'm due for an oil change but the car doesn't indicate that I should. So should I go off the car warning light or the sticker?
Last time I brought my car in according to the sticker and the service rep told me I don't need an oil change yet because the car didn't indicate it. Not sure if I can totally trust service reps hehe.
You have to remember the OEM recommendation is based on using dino oil and the 5K mile interval is based on severe use. The best way to determine how long your oil is safely protecting your engine is to get a UOA. In the end it will save you time and money. It also eliminates the guessing and will provide a record that can be used if there is a warranty issue. Why guess?
Koz
Koz
