MRM + FiveAxis S5:F + PIAA = Best combination ever
#31
Yeah ... that was a little close, but the lip clears by like and inch so its all good
#32
Thanks again for the comments!
jns350,
No, I ordered through tirerack and went to Topline in burligame to install them.
D.Jobin,
Im not lowered, but I do rub on turns (tires a little wide maybe?) ... just a little though. But I need to find a heat gun or someone to help be push back part of the fender lining ever so slightly.
IntegresS,
I don't rub on dips, or straight roads, but I do rub on turns ... right under the driver on left turns and under the passenger on right turns. Ill post a pic later.. (and im running 235/35 ... )
jns350,
D.Jobin,
IntegresS,
Ah yes yes mine used to rub on turns-- that little tab thing under your fender needs to be pushed so that it doesn't dig into your tires on turns (and dips, once you lower it).
My front tires got a little chewed up looking from hitting that tab under the fender before I had it pushed back, but...I still rub on dips and over bumps, and I'm only lowered on Eibach =/ rolling fenders may be in need!
#36
man that combo looks SIck with it. im not an epert at taking pics but i always think that further away pics with a little bit of zoom look better.
again Bad *** ride, ncie detail on the lug nuts
i used a heat gun to heat te plastic liner and puch it in, no rubbing after that
#39
hah, i'm honored. I should've gotten the 19's -- and looks like your lugs are more red than the works.
I just got the is-f tails and did a very light tint with vht ((-) the clear parts) and looks dope with the whole look.
I'm getting kind of tired of my red lugs though, might look into black or Ti. Looks great, post some pics when you drop it
