DOT3 or DOT4 brake fluid?
I'm about to swap out my front and rear IS250 brakes to IS350. Should I use DOT3 or DOT4 brakefluid? Toyota recommends DOT3. What brand should I get if I go DOT4?
2IS/2RX/4RX
From StopTech website
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Does this make DOT 4 fluids better than DOT 3 fluids? Not always. Remember, the boiling points listed are minimums and there are DOT 3 fluids out there with higher boiling points than some DOT 4 fluids. The real differentiating factor should be that if you run a DOT 4 fluid you really should change the fluid more often than if you use a DOT 3, if for no other reason than the rapid fall off in boiling point with time.
thanks for think! great reading.
"As a trailing note on the DOT ratings, if your car was designed for a particular type of fluid (especially prior to the development of DOT 4 fluids), you should make every attempt to stick with that fluid! For example, if your car was delivered with DOT 3 fluid, the internal components of the system (seals, brake hoses, and fittings for example) were specifically designed and tested for compatibility with DOT 3. Because DOT 4 fluids contain a different chemical composition, the system may not necessarily react in a positive fashion to the borate esters floating around in the mix."
So I guess should just stick with the OEM TOYOTA DOT3.
RG3toDC
10-28-18 03:07 PM
