Oil Change - 5w-20 or 5w-30? What everyone is using?
Old 08-03-09, 02:10 PM
aboss3
aboss3's Avatar
Default Oil Change - 5w-20 or 5w-30? What everyone is using?
I wanted to start this thread to see what types of oil is everyone using for your IS?
I just switched to 5w-20 Mobile 1 per Lexus & Toyota new suggestions vs using the 5w-30.
Anyone else is also using 5w-20?
Old 08-03-09, 02:31 PM
Clay Easto
Clay Easto's Avatar
5W-30 conventional oil
Old 08-03-09, 02:44 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I was using 5W20 for a while.....now switched to 0W30
Old 08-03-09, 02:48 PM
92 SC400
92 SC400's Avatar
0W30 for me too.
Old 08-03-09, 02:56 PM
aboss3
aboss3's Avatar
why 0w30? I see you're in hot climate also.
Any reason for using that 0w30?
Old 08-03-09, 04:26 PM
Hoovey689
Hoovey689's Avatar
5w-30 Chevron Supreme every 3K
Old 08-03-09, 05:04 PM
Koz
Koz's Avatar
Up to 80% of engine wear is from cold starts. This does not only pertain to cold weather. Cold start means the first start of the day after the engine has completely cooled/drained down. This wear accrues in the time the oil takes to get to the vital parts of the engine (bearings, cams, lifters, etc). The quicker the oil gets to those vital areas the less wear. That being said, the lower the weight the better/faster the oil will flow during start-up. The IS, along with most modern engines are using 5w-20. The “w” represents winter and is the important number to look at when determining cold start flow. The lower the number the better cold flow.
I was using 0w-20 for the first two years and now I am using 0w-30. I will soon see which shows better in our engine (3.5), by analyzing UOAs (Used Oil Analysis). I am VERY hard on the engine (High RPMs quite often).
Koz
Old 08-03-09, 05:31 PM
Bichon
Super Moderator
Bichon's Avatar
I use 5W20 Penzoil Platinum.
Old 08-03-09, 05:44 PM
A1Lexis
A1Lexis's Avatar
I use 5W30 where the temp's here rarely get below 32F.
Old 08-03-09, 06:51 PM
gs400998
gs400998's Avatar
I use Mobile 1 0w-30.
Old 08-03-09, 06:54 PM
llamaboiz
llamaboiz's Avatar
5w-30 of the purple stuff
Old 08-04-09, 12:35 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Cos' it's the same price at Wal-Mart! LOL
Old 08-04-09, 12:40 AM
eric_r_ho
eric_r_ho's Avatar
0W-30, Mobil1 w/ the bright green cap
Old 08-04-09, 12:47 AM
pingu
pingu's Avatar
Koz
http://www.ferrarichat.com/forum/faq...=haas_articles
One of the best 0w-30 is the german castrol syntec
Old 08-04-09, 04:14 AM
Koz
Koz's Avatar
A Ferrari engine is at the far end of the spectrum compared to a Toyota/Lexus engine. Toyota/Lexus engines are gentle on motor oil so any brand pure synthetic oil will be overkill, especially if you are following the OEM recommended OCI (Oil change interval). With a quality synthetic you can safely use a one year or 10K mile OCI, on our engines.
I've had great results with Amsoil 0w-30. I installed a oil bypass system on my V8 4Runner. I've been using this oil now for 4 years (Never changed) with 40K miles on it and my last UOA shows no end in sight yet. Usually 0w oils have the best additive packages and are the highest quality (For street use) oil each manufacture makes. You can’t go wrong with ANY 0w oil.
http://www.amsoil.com/storefront/sso.aspx
Koz
Quick Reply: Oil Change - 5w-20 or 5w-30? What everyone is using?
