IS350 Turning Signal RELAY!!!
I have a 2007 IS350 and I need to find the blinker relay to replace it. Also how do I access this area!? I THINK it is by the driver side wheel well in the cabin...can someone PLEASE help me??? I'm desperate!
it's way up behind the steering column. you'll have to lie on the floor with your head facing up. remove the plastic knee cover. turn on your hazards so you can hear the clicks. it'll be hard to see up there but if i remember correctly, it's a small green box. feel around for the clicks. it's also a very tight squeeze! the hard part was unclipping the plastic bracket from its holder. good luck!
konacoffee
05-01-21 10:52 AM
