spacer question
my front two tires are rubbing when i got my 10mm spacers installed with the extended studs so i'am going see if the 5 mm will rub..
if i want to install my 5mm spacer would i need to swap the extended stud from my 10mm or can i use the same extended stud and save myself a whole lot of time
thanks
thanks
Vip.Status
05-17-11 04:54 AM
