One more tire/awd question....
Ok just got some OEM 18s off an 07 is250.... the tires are 225/40/18 fronts and 255/40 rears i think...
The fronts i know need to be 225/45/18 and on the way home my awd warning came on and then the sensor(something else came on) is it ok if i drive like this for like a week?
or do i need to replace the tires asap like tommarow>? thanks![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
The default 18" tire setup will not work. I would not even drive with them on to be honest. Which is why I am scared since I am running a larger overall setup, if I ever bust a tire on a road trip I don't think I even can drive home on the smaller spare
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Tech Info Resource
Sounds like you're really pissing off the center differential. It might be very expensive to continue driving on it.
Thats what i did....lol thats funny... i hate this AWD crap but thats the only thing the dealer had and could put me in
^^ lol now i talked to my friend at a local shop he said to go and just get 2 more 225/45/18s and then everything will be fine and back to normal with no light on. so i guess thats what im going to have to do...
is anyone sure this will work?
This is what I went by when I did my staggerd.
http://www.miata.net/garage/tirecalc.html
My rear tires were .5" larger but it still didn't trip the light
What do you mean? I just saw love67 mention that he heard from Lexus tech that its okay within a 1" diameter, so I just did mine according to what is okay for my rim width.
235/40/18
275/35/18
Your warning should of went away after, if not then the dealer should take a closer look to see if there are issues or that the code just got stuck. :/
235/40/18
275/35/18
I did 225/45/18 and 255/40/18 and they are the exact same almost... but could it be because i already tripped the sensor and then replaced the tires, thats why i still have the light on?
