If you're in SoCal, you probably have a Fry's Electronics near you. I got it there for around a buck.
+1 that's were I got mine from....good ole Fry's Ele..
BTW..FYI there is way to start your car if your key remote battery is dead.
here is the link http://www.youtube.com/watch?v=m1KdvOQxP-o
You don't even need a penny, I was stuck after going dragonboating with a low battery, so I just used the regular key and jammed that in the gap and twisted it to open it. Might damage the key over repeated use...but key stronger than plastic..
Exactly--it's designed so that the tip of mechanical key that slides out fits exactly in that slot--and you can't access the slot unless you pull out the mechanical key anyway.
