Nav Hack, can we replace wire harness?
Not too familiar with the whole electrical system, but I did the Nav hack a while back and now I'm having issues with the DVD player. I want to eliminate all possibilities, so I'd like to replace the wire harness that was cut. I think there were 2 wires that were cut, don't rememebr if they were from the same one. Anyone know the part number? How much it would be? Where I could get it?
Thanks
Thanks
Tech Info Resource
I really hope you're kidding about replacing the harness. It's expensive and requires removing the dash. This is why I never cut a good harness.
if you're talking about the P1 its like $100, the J50 isn't possible to replace, you have to build it or have lexus build it. the connector is around $5, and then each terminal is about $10 each, the J50 has about 26 terminals. do the math...... like lobux said hopefullly your kidding, it would be cheaper to find a donor harness at a junk yard, which is a hard find.
lexusdod
04-25-14 10:35 PM
