Need Help: Broken Accelerator Assembly
Good evening,
I broke something and could use some (specific) help.
In the process of install my sport pedals, I broke the the accelerator assembly. Specifically where the upper right bolt (and subsequently the nut) goes the plastic housing broke which means the top right portion of the accelerator assembly won't tighten properly.
I apologize if the description is sketchy, but the gist of it is I need the plastic housing for the accelerator housing. The part number on the housing says Denso 78110-53031 and the next line says 198800-7860. I'm assuming that is the entire pedal assembly, and I just need the plastic housing, but I realize I may have to buy the entire thing. /sigh
I've already done a toyota/lexus part search, and called some salvage yards, and I plan to get a quote from the dealership tomorrow, but I could use some specific suggestions (like specific vendors, etc).
If you have any specific ideas (i.e. not ... do a google search, or contact a denso reseller, etc. because I've already done that), then please let me know.
Ironically, I did the F-sport Intake install tonight and it went pretty smoothly.
/sigh
Thanks for any help you can offer.
/sigh
Tech Info Resource
Plan for frigid temperatures. You won't find a smaller sub-assembly for sale anywhere but maybe a junkyard.
I'm not very happy with myself. I can't believe I broke it even utilizing an angle adapter. Although I blame myself, I wish some of these things would be made with some metal. :-)
I started filling out forms with salvage yards and used part dealers, and I'm hopeful I can find something soon. If not, I may try plastic solder. /sigh
