Paddle Shifters don't respond quickly?
#31
Tech Info Resource
If you're going 40 mph in 6th and you hit the paddle for 5th you'll get 5th. If you floor it, it will downshift to 3rd without any intervention on your part. That's the problem. If I ask for 5th, I want 5th and no other gear. You can't do that with the 350 or the 250.
#32
#33
Tech Info Resource
True enough. There's a reason my Supra sits next to my F. Still, the paddles were one of the driving forces pushing me from the 350 to the F. It's incomparably better.
#34
Many of you have pointed to the car 'learning your driving style', does anyone know how much driving is required to make the car behave like a fuel efficient car vs a sports car? So, if I drive conservatively for an hour is that enough for the ECU to behave differently...?
#35
I doubt 1 hour is enough.
If you don't like the way the ECU behaves it's no big deal, you can always reset it (I think?) at the stealership
Can anyone confirm/deny
#36
And by the way just for clarification, the "fuel efficiency" comes from the car tending to put you in higher gears more quickly and more often (5, 6)
At full WOT with trac/vsc off you will always get maximum performance. It's just how the ECU shifts you into the highest gears during partial throttle that is a function of the ECU "learning" your driving style.
For example, after 2000 miles of pretty soft driving (I really don't have the opportunity to drive aggressively/accelerate quickly, I'm living in slowpoke land here) if I'm cruising at 65 in 6th gera and give maybe 35% throttle, the car will shift me into 5th for acceleration.
In ECT PWR mode, if I do the same thing (cruising at 65 in 6th gear) it will put me into 4th gear instead of 5th
#38
After so much of that the ECU finally learned and the it's perfect for my driving conditions now.
How do you reset it again, or is this in the manual?
#40
Tech Info Resource
Because they did it right in the F, and it's better than a manual. So they CAN do it, they just choose NOT to do it.
#42
IIRC they F transmission is a significantly modified version of the one in the LS, modded to offer exactly the kinda behavior we're desiring here (better than a manual performance, shift speeds, etc)... they COULD now work on modding the transmissions in the ISx50 in a similar fashion, I mean, I'd love to have the shifting of the F too, but at this point in the product cycle it makes a lot more sense to work on that for the 3rd gen IS than to try and add squeeze it into the last year or two of production on the 2nd gen car.
#45
To add to that, the trans' programing is amazing as to selecting the best gear and how fast it shifts. At WOT the trans keeps the engine's RPM in the perfect power range. Also when using the power mode the trans even downshifts sooner under hard braking to really help shed speed. One of the slickest ordinary trans I have ever owned.
Koz
