Paddle Shifters don't respond quickly?
Does anyone else experience this? When I shift around 4-6RPMs it takes the car a few seconds to shift and the RPMs go all over the place sometimes. On my A4 with the paddles it's pretty much instant. Anyone have this problem and any way to fix it?
I honestly think that Lexus place these paddles for our amusement only...they do seem to "think" before the gear changes....so your situation is unfortunately normal....but I can only imagine how useful they are on your dad's Ferrari
When I shift with the paddles, I can count to seven before it shifts ( OK, I am counting very quickly, but just the same, I can count to seven ) . The system is a joke.
Your Audi must have the dual clutch transmission. The best system going. Period. Seems that all the top performance cars are going that way.
Yeah I hate calling them paddle shifters also, complete misnomer. Let's start calling them gear limiters (aka what they actually are), and they do have limited use (primarily with the down gear limiter) when you think the car is putting you in too high of a gear.
I'll give you a relevant example of where I use them. I actually made a thread about this recently.
I am at a T junction (at a stop sign). In front of me is a 65 MPH freeway. Thus, I need to take a sharp ~90 degree turn in order to get into this 65 MPH freeway.
I cannot accelerate hard from the start, that would completely cause the car to lose control. There's too much hp/torque to do that on a 90 degree turn AND there is a small annoying "mini speed bump" that separates this freeway from the stop sign, so I like to ease over it.
I ease over it and what happens next? The car automatically puts me into 2nd gear in about a second and I am going about 5 MPH and am finally on the freeway.
Well, I don't want this. I don't need to accelerate from 0 in 1st gear, but it would be nice right? Otherwise what's the point.
I press the down gear limiter and thus force it into 1st. I start accelerating and IMMEDIATELY after I start accelerating I press the up gear limiters back up to "6" as fast as possible.
All of this can be done in "D" mode for me because I have the '09 version.
Back during break in period I really babied the car a lot and as a result the ECU felt the need to constantly put me in the highest gears possible for saving gas, which is fine this is what I actually want 99% of the time.
But for this 1% I prefer aggressive shifting (aka start in 1st gear not 2nd) and the gear limiters let me do that.
This is not to say the gear limiters are more useful than actual manual transmission. MT is far and away superior, but the gear limiters do have limited use (no pun intended)
Actually that pun was intended.
Tech Info Resource
This was one of my deciding factors for the F.
2IS OG
The S-mode and accompanying paddle shifters are not really "shifters" in that they don't actually shift gears, nor were they designed to - they're merely a mechanism for manually selecting the gear range. Following is Lexus' description of the paddle shifters, taken from the New Car Features section of the FSM:
By moving the shift lever to the front (“+” position) or to the rear (“-” position), the driver can select the desired shift range position. Also, the shift paddle switch is adopted, which enables changing the shift ranges while the driver is holding the steering wheel. Thus, the driver is able to shift gears with a manual-like feel.
This Multi-mode automatic transmission is designed to allow the driver to switch the gear ranges; not for manually selecting single gears.
Javier
I do not notice any difference in shifting time with the paddles and gear shifter. They are both slow. But I agree about the F's unit. That thing shifted absolutely instantly and was amazing. I'd so pay extra for that tranny, it's not even funny. I pray Lexus gives us that thing with the 3IS.
The manual mode should be used to keep the engine in the power curve (RPM range) when going to pass or going through/out of a curve. You can also use the manual mode to shed some speed. The manual mode on the IS does not make the trans a manual, it only allows you to select a lower gear when needed. I found the manual mode to be very effective when I am playing with another car. I can sit in a low gear, with revs up, waiting for a break. As soon as I get my break, I paddle up to 5th so I can concentrate on driving and let the trans take care of the up shifting (The speed limiter kicks in on 5th gear so 6th gear is not needed, at all, when playing). If there is a need to start from a lower speed again, I simply paddle down again.
Koz
Koz
